XJ8 Fuel Pump Failure or ECM?
Good Evening,
I am troubleshooting if I have a bad fuel pump or ECM. The car was running fine before turning off. I tried to start about five minutes later and the engine started then Engine Stalled indicator came on dash. I tried with pedal to floor and it would not start. kept trying but no luck. Removed fuel pump relay and replace with another relay. Pressure is 0 coming from fuel rail. Also driver and passenger seat heater and rear defroster is not coming on. all was working prior to engine stalling.
fuel pump is more likely than ecm
figure out with the owners manual, electrical diagrams, and the electrical diagrams from
downloads in the forum stickies which pin at the trunk fusebox leads to the fuel pump at
the tank. jumper 12V to that pin momentarily. if the pump is functioning you will hear a
faint whir. if there is nothing, the pump is dead. the test is definitiive.
if you jumper power to the pump, and the car starts normally, then it might be the
relay, or relay fuse.
bandre2 (12-08-2015)
Good Afternoon Plums,
Appreciate the quick response, I removed the fuel pump relay and inserted a paper clip on pins 30 and 87 with ignition key both on and off and no sound from pump. I did hear the relay click when turning key on and off no pump sound. have you changed this part before? Is there more parts involved in replacing besides the pump itself? seals? wire harnesses? Please advise.
jagnation89
10-17-2015 01:48 PM
Joe Kelley
02-26-2013 07:52 PM
