XJ8 Help
Looking for advice on replacing the Denso Marston MNC 4205AF 9019 radiator on my 1999 XJ8. What should I expect to pay a dealer and or if replacing myself, I need to know how to replace transmission fluid that will be lost and how to know when the fluid is at the correct level.
Regards,
Ray Robinson
Regards,
Ray Robinson
Welcome, I don't know about prices but I can recommend our vendors for you to buy parts
www.nalleyjaguar.com
www.gaudinjaguarparts.com
park place
alternatively you can also buy it from other sources
www.jagbits.com
www.motorcarsltd.com
park place
www.jagbits.com
Ray Robinson (11-02-2011)
RE TRANSMISSION: Hello if you search the post "Questions for 03 XJ8 transmission fluid and filter replacement" by chernobee, that will give you a picture of the transmission and some advice. The second posting will have a link to another thread with that particular section of the service manual that is downloadable in pdf. You will need metric allen wrenches, jack stands and a beer bong <big tube connected to a funnel> to fill it. The jaguar fluid is pricey, many full synthetics for the zf transmission will work. Ill be using pentisol this time. Good luck
