XJ8 intermittent no crank
Guest
Posts: n/a
Once every few weeks my 2000 3.2L xj8 will not crank. At the same time the instrument lights all go out just as if the battery is disconnected. I turn the ignition key off and on and the cat springs to life. Also my scan tool shows P1649 - flash memory -FCCP monitoring malfunction. I dont know if this is related. I have checked battery terminals, connections on the false fire wall and earths. Could this be intermittent key transponder coil or ignition switch. Thanks for any advise.
Ivan
Ivan
ericjansen
12-19-2021 01:20 AM
Will P
09-19-2018 09:36 AM
2000, 2003, crank, cranking, fccp, flash, intermittent, jaguar, jaguarflash, malfunction, memory, monitoring, p1649, xj, xj8
