XJ8 K&N Air Filter?
Received 2,263 Likes
Don B (10-22-2015)
I would suggest adding a secondary inlet into the airbox, a tube down to behind the grill area to allow more air in than just the fender. I didn't dyno my car before and after, and I went to a cone intake anyway, but even if it does gain you some, it's not going to be noticeable, especially if it's the drop in replacement. The cone filters give you more sound but can't swear that it's power and not noise. Mileage won't be affected much either, you'd be better off doing the routine stuff (plugs, keep oil fresh, good gas, clean the MAF, etc) to keep mileage up to a premium. The filter won't really make a difference, even if it does give you a hp or two bump (again, I haven't seen a before/after dyno run with like conditions for both runs, so I can't speak to that. I've seen some videos where the K&N does do some, but each car is different)
Don B (10-22-2015)
Don B (10-22-2015)
Odd you say that, my Infiniti is giving me my 1st problems since ownership. It was recently switched over to K&N as well. All symptoms/codes point to the MAF sensor I cleaned it & still get idle issues , now I'm waiting on a new MAF sensor to arrive & I may just go pick up a paper filter lol.
I owned an XJ8 and wanted some more go. So I saved and bought an XJR. I drove the XJR for a while and wanted more go. I saved and bought the XFR. For now, I have all the go I want and then some.
I suspect that I have actually invested less money, and certainly less time than the guys whop have truly gotten significant HP gains. But I have missed out on the fun and bragging rights and the chance to lie about my improvements.
The following 2 users liked this post by sparkenzap:
Don B (10-22-2015),
motorcarman (10-23-2015)
The following 2 users liked this post by 80sRule:
Don B (10-22-2015),
sparkenzap (10-22-2015)
Just "bolt a supercharger on it" and be done with it.
Just kidding!
Really, get an XJR instead!
Some of my Ferrari buddies run the K&N with NO OIL, believe it or not, because they want the extra air flow, are not afraid of the extra particles not filtered by the unoiled K&N, but ARE terrified that the oil will mess up their expensive F car MAF. We are talking about cars that get driven a hundred miles a month sometimes though.
I think that speaks volumes about the danger of an oily K&N.
Vector
Just kidding!
Vector
Received 12,942 Likes
ratgawd,
There's an easy way to test for any perceptible improvement in performance that could be gained by using a K&N filter. Simply drive your car with the air filter removed. It's best to do this after a rain when the air has been washed of dust and insects.
Whatever performance difference you can perceive is the maximum improvement a K&N filter could provide. But in reality, the actual difference will be less, because any air filter must, by its nature, restrict air flow. The biggest difference you'll probably notice is a little more induction noise, as CharlzO mentioned. Any performance difference you notice will be mostly or entirely placebo effect.
As Vector mentioned, an air filter that can allow more air flow can also allow larger airborne particles to pass, so I use OEM style paper filters in our cars.
Cheers,
Don
Cheers,
Don
The following 2 users liked this post by Don B:
motorcarman (10-23-2015),
ratgawd (11-03-2015)
Don B (10-23-2015)
Johnken
11-16-2015 02:26 AM
klintous
10-28-2015 01:33 AM
