XJ8 LS Swap Project
XJ8 LS Swap Project
Starting this thread on my project. I’ll post regular updates.
This is the project car. 2002 XJ8 with a clean title and shot tranny. Sold the engine and cats for $1000 more than I paid for this car.
2001 XJR parts car. Bought for interior and wheels. May also switch some suspension parts. Already parted out on EBay several things for a few hundred. Engine and tranny for sale. (Car is also in Marketplace.). If I get what I’m asking for engine and tranny, I’ll be ahead.
2011 Chevy Camaro with 6.2L L99 and 6L80 automatic transmission. Parting out everything else.
Jtestrake (09-10-2022)
What transmission and differential are you going with?
Also, what’re your hp goals with the LS?
I seem to remember another member with a X308 LS project a number of years ago but, I believe that went unfinished.
I’m sure you’ll figure it out but, I seem to recall an issue with the oil pan clearance situation. Perhaps keep in mind a dry sump.
Good luck with the project!!
Camaro AT 6L80. Jag differential.
Stock hp is 403. Could easily get another 60 with a hotter cam without changing converter. L99 is a LS3 with Active Fuel Management. Changing cam requires switching out AFM lifters and putting a limiter on the VVT. Hard to put more than 400 hp on the ground with the tires we have, so no immediate plans.
I seem to remember another member with a X308 LS project a number of years ago but, I believe that went unfinished. I’m using the Jaguar Specialties kit, so manual and no fabrication.
Stock oil pan way too big. Kit came with GTO oil pan. Some cutting and required to make it fit.
03_jaaag (07-05-2024)
Yes, miniature donkeys. Fully grown about 250 lbs. Also have 2 horses, 2 goats and 20 chicken. Used to have pigs, but gave them away.
ericnunez (04-25-2024)
The following 2 users liked this post by pcolapacker:
nilanium (02-04-2023),
Z07Brandon (01-14-2023)
Coolant and fuel lines
Hooked up coolant lines to reservoir and heater. Jaguar electric water pump not required.
Uses ‘99 Corvette fuel filter because it has an internal regulator. Would rather have shorter run from filter to engine but could only find male/male metal connector in 12 inch length.
Addicted2boost (02-03-2023),
Will have A/C. Uses all Jag parts except for compressor. Looks like I’m going to have to mount a compressor high on engine because current location blocks dip stick because required GTO pan has a front sump.
