XJ8 LS Swap Project
#42
The following 2 users liked this post by pcolapacker:
57loboy (06-26-2023),
Addicted2boost (06-14-2023)
#45
#46
#49
#50
That's excellent self-funding build arbitrage. My Camaro donor car arrives within the next hour or so. Am hoping for similar cost recovery. My XJR was $1,600. Fingers crossed...
#51
Remember the big $ for the XJR cats. See my post. Besides the kit price, my only big expense has been the drive shaft. I can give you that guy’s name and also someone to reflash the ECU if you don’t have someone local.
alistairolsen (08-01-2023)
#52
The following 3 users liked this post by pcolapacker:
#53
#57
That should keep you busy for a bit... Can't wait until my kit gets here from Andrew. Finally moved the 2000 XJR back into the garage so it's at least in the right place to "start" being a project car/LS-swap recipient.
#58
Found online the diagram for the Camaro ECM that shows the pins and wire colors. I’ll send to you when you need it.
57loboy (10-01-2023)
#60
