XJ8 misfire codes
XJ8 misfire codes
Hello all, just bought my first jaguar, a 2003 xj8 with 90k miles. It shakes at idle, and is hesitant to accelerate and shakes even more and shows an error code saying "gearbox fault." I got the engine codes checked and had the following come up:
P0306 Cylinder 6 misfire
P1314 No definition
P1316 No definition
P0460 Fuel level sensor A circuit
P0743 torque converter clutch solenoid circuit electrical
P1000 No definition
The shaking at idle I assume is the misfire, any help as to what the P1316, 1314, and 1000 codes are? And would they all be related? The car had not been driven for about 6 months,so could the P0743 be due to a weak battery, or is that a more serious issue because of the shaking when accelerating? After driving the car home about an hour, i could not notice the difficulty to accelerate beyond the misfire, so am not sure if that may have cleared itself up? I am entirely new to jaguars, and any help is hugely appreciated!
P1314 No definition
P1316 No definition
P1000 No definition
The codes are explained with causes in the workshop manual (free download here) and some info is on JagRepair.com - Jaguar Repair Information Resource
Ignore gearbox faults until you've fixed eery engine code as usually they're caused by the latter.
Battery is #1 suspect except perhaps for P0306 and related codes.
I just pulled the plug from cylinder 6, then pulled the plug on 4 as well. They're both pretty fouled, so I'll pry replace all the plugs, but cylinder 6 is dry and 4 has some gas on the plug. I'll try to attach a picture, 6 is on the right. Does this mean it's a bad fuel injector on cylinder 6?
Gblauf
03-03-2013 09:36 AM
