XJ8 overheats
The easiest test is start it, Push the climate control panel down again and again until the screen says LOW. and then turn the fan control knob for max fan.
Now is the electric fans running like the are trying to cool the desert. If yes shut down the AC. If no then the fan controller or the fans themselves have quit working.
Next let it sit and idle to warm up do the fans come on and shut off. If yes then get the systems flushed and refilled. If no then back to bad fans or controller.
12 volts can be applied to the fans to see if they run and if they do that would point to the controller.
I just realized the error of my ways check fuse 12 in the engine compartment fuse box it powers the fans. Duh simplest first.
Received 1,813 Likes
Highhorse (09-16-2018)
FS[NorthWest]: 1999 XJ8 for sale
motorhommie
10-19-2016 02:28 PM
winefan94920
10-16-2016 02:52 PM
Igloo112
09-07-2007 03:42 AM
