XJ8 secondary timing tensioner replacemet questions
Hi, I have a 1999 XJ8 that I would like to replace the secondary tensioners on. I've read a lot of the forums on this and I'm getting confused. Can you some list the step by step instructions to do this? With pictures.
I've read that the crank needs to be locked and then I've seen forums that people are doing it without locking the crank. Locking the cam shafts are a given. Is there a forum listing that I'm missing that gives clear instructions on how to get this job completed successfully?
Thanks.
Thanks.
I know it is difficult visualizing something that you have never done before but the secondary tensioner replacement is not difficult.
Read through these and then try some specific questions.
Cam Chain Tensioners - Removing Valve Covers Only
https://www.jaguarforums.com/forum/j...17/#post316489
Help - sudden fail - Jaguar Forums - Jaguar Enthusiasts Forum
I just changed my own timing chain tensioners........ - Jaguar Forums - Jaguar Enthusiasts Forum
Ford tensioners for Jaguar??? - Jaguar Forums - Jaguar Enthusiasts Forum
Tensioners, when are they a "must replace" item? - Jaguar Forums - Jaguar Enthusiasts Forum
Free File Sharing Made Simple - MediaFire
DIY ~ Jaguar 4.0 (R&R) Timing belt, Tensioners, Water Pump, etc. - Calguns.net
Cam Chain Tensioners Lincoln LS Part Numbers
https://www.jaguarforums.com/forum/j...34/#post330655
JTIS .pdf files on Chains/Tensioners replacement
https://www.jaguarforums.com/forum/j...prokets-54603/
Cam locking tool dimensions
Welcome to Jag-lovers - Members Photo Viewing Page
Cam Chain Tensioners Cam Removal Method 2nd tensions DIY instruction FAQ - Jaguar Forums - Jaguar Enthusiasts Forum
Broken Cam Due to Removing Cam
Cam shaft woes
Cam shaft woes
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
The whole point of the zip tie method is that it is easier - you don't need to lock anything down. But it is not compatible (I don't think) with replacing the secondary chain. The whole point of the zip ties is to maintain the same number of links between the appropriate teeth on the sprockets.
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
Bcrary3
08-31-2015 11:29 AM
Will P
08-27-2015 06:52 PM
1999, check, instructions, jaguar, loosen, replace, replacment, secondary, tensioner, tensioners, tentioner, timing, tool, xj8, xjr
