Need help. Posting for boyfriend. Car has had pcv valve replaced, new coil packs, new plus, new filters, oil change, we have worked on the coolant system. Still smoking. Gets worse when it gets hot. Smoking out driver pipe worse than other. Thick white smoke and knocking. Sat up for 3 years before we got it but ran perfect when we drove it then. Video enclosed.
Engine smoking and pushing oil up on top of engine. No idea why? Driver side worse
Smoke from the exhaust can only mean one thing, you're burning something that isn't 'usual'. If it's white smoke I would suggest water being burned in the combustion chamber. If it was oil, the smoke would be pale(ish) blue. You may get an indication from the smell of the smoke, if it's oil burning you will know. Maybe the knocking would be the increased compression having to accommodate the water or oil present in the chamber? I've seen this before, both water and oil burning .. and funnily enough, when it was water burning, my glasses steamed up when trying to smell the smoke, didn't happen with oil burning! Does either the water level, or oil level go down?
