XJ8 Speaker size conflicts 5.25 or 6.5? Results!
Old 07-21-2010, 09:51 AM
Sinister 1's Avatar
From my wrecked 2000 XJ8 the tweeters behind the door handles are 1.5" in diameter. The problem is they are bonded into the bracket that snaps into the handle base. I doubt it will come apart without damage.
Expect to fab the mount brackets.
When in place, it's a pretty tight package as you only have about 5/8" to work with for depth otherwise you crash into the steel door inner.
Here is a shot when it's in place.
Old 07-21-2010, 10:06 AM
Sinister 1's Avatar
Default Getting the thread back on track. :)
The original statement was 5.25 or 6.5... Hopefully I can add some clarity.
Here is a door speaker removed from my wrecked 2000 XJ8. It should technically be sold as a 5.25" at any electronics shop. However the marketing people of the world have decided to go with a bigger is better mentality so some companies call a 5.25" speaker a 6.5". It can be confusing so depending on what brand you are looking at you'll want to know the actual sizes in your Jag.
As a standard, Speakers are measured as the useable surface of the cone like this:
Here's the dimension of the OD of the speaker. This is not the correct way to spec a speaker but it will assist in making sure the holes are placed correctly so they will bolt right in.
Here's a shot of a front and rear door panel with the factory 5.25" round 4 ohm speakers installed.
Old 07-21-2010, 11:02 AM
jima's Avatar
Originally Posted by judas74205
Ok So yesterday i was bored as hell at my house so I took it upon myself to get the speaker out of my 1999 XJ8. There has been conflicts on websites and forums about the size of the all four speakers. But I finally have the real answer.
You could have saved yourself the effort, I already did it
https://www.jaguarforums.com/forum/s...ad.php?t=27074
kevinl
10-31-2019 06:15 PM
mbergen
10-23-2019 10:26 PM
Gerard Radimaker
09-13-2015 10:33 AM
RaceDiagnostics
09-07-2015 07:28 AM
Quick Reply: XJ8 Speaker size conflicts 5.25 or 6.5? Results!
