XJ8 Speaker specs? recommended upgrades?
Has anyone got the specs' on these, preferably Alpine, but the Harmon Kardon (Phillips) speakers will help also in this thread.
for example, peak/rms power, frequency response, sensitivity.
Reason I ask, a future update would be to refresh the door speakers, I've a premium system with sub and amp, but might go so far as to switch these out also.
Anyone upgraded their system speakers? any recommendations? Any Problems?
Sean, here are a few links for door speakers; direct replacements and almost so.
I wouldn't say it was difficult, mostly plug&play.
crutchfield.com/p_500SPS600C/Alpine-SPS-600C.html?tp=95
amazon.com/Phoenix-RSD6-5CS-Radial-Component-System/dp/tech-data/B000TBQ8QU/ref=de_a_smtd
buy.com/prod/alpine-type-s-sps-600c-speaker-2-way-80w-rms-240w-pmpo/q/loc/111/208033492.html
mobile.jlaudio.com/products_components.php?comp_id=125
caraudiomag.com/articles/phoenix-gold-rsd-65cs-speaker-review
Sean B (09-30-2011)
Speaker project
Just about to embark on this myself - Sean B i am also from sunny southport though now living in houston texas - I have the standard speakers in my 98 xj8 they are more or less standard 6.5inch speakers. they have 4 screw holes on the diagonals . They have foam padding at the front so they're not flush really with the door card. They're 2.5" in depth - many 6.5 are 2" so depth for once this should not be a problem. They're 4 ohm.
Basically any 6.5inch with the multi screw holes should fit - it does look like foam padding on them at the front will be needed but thats fairly easy to jury rig. All my 6.5inchs have gone in my car but there's a lot of door card shinanigans to sort out before i replace them (naming getting all the clips!) - the tweeters still work well so I'm steering well clear of changing them.
I'll post what speakers I get and how I get on. I'm not looking to go high end just ones that arnt cardboard like the jag originals. Any butyl, polypropylene speaker will make a massive difference.
Does anyone out there know the jag colour coding on the wiring for positive and negative? I figured I'd cut and splice the connectors rather than get these:
Speaker Harnesses Speaker adapter plugs for select 1989-up Jaguar, Porsche, Saturn, VW, and Volvo at Crutchfield.com
though they do make life a lot easier.
Anyone change out the grills while replacing the speakers? My stock grills are cracked and I am wondering if I might go with a speaker whose grills would make a suitable replacement, all other specs being sufficient. Polk, for example, makes a 6.5 with a tasteful grill (DXI650).
Is major plastic surgery required to change the grills?
aholbro1
08-05-2021 05:02 AM
hafren
09-07-2015 10:30 AM
