xj8 spot lights
Hello and welcome to the forum Tel, fogs or main beams? Also what year/model is your car.
The relays for both are in the large fusebox, passenger side front under the bonnet, the relays are arranged in a T.
The 3 relays that form the top of the 'T' - centre is fogs, right side (nearest front of car) is main beams, switch them to see if it's the relay as they're the same.
Hope this helps, invoice in the post.
El Tel (05-09-2017)
Digital Will
03-06-2020 03:50 PM
FS[SouthWest]: XJ40 used Rear Spring set for NON-SLS
motorcarman
10-12-2016 11:36 AM
equicor
10-03-2016 09:30 PM
