XJ8 Stability Control Problem
Guest
Posts: n/a
Hi,
I am attempting to diagnose a stability control problem on a 99 XJ8. The light comes on randomly and the car goes into derate mode. When the car is turned off and restarted the light goes out and the the car operates normally. I checked all the wheel sensors with an ohm meter. No problem found with them. I also disconnected the battery to reset the module ( read this somewhere ???) Any ideas? It's driving me crazy. I don't want to spen the money for a module without being sure this is the problem.
Thanks in advance for any advice.
RE: XJ8 Stability Control Problem
'99 XJ8 .................................................. ........., prime candidate for a new battery,
as an aging battery will throw spurious fault codes out leading you up the garden path,
unless you know its a new battery and its good, it a good cheap alternative to chasing ghost problems , though you should still get things checked out properly
hope this helps
BB
hope this helps
BB
week battery will usually just make the trac not available flash on momentarily when car first started
then goes away and usually doesnt present a fault afterwards
that is until next engine start
first thing first get the code read and then let us know what you have for a code
