xj8 starter replacement!help!
Starter
Hi RidenXJ8
The Starter is on the passenger under the engine passenger side. Make sure the battery is disconnected prior to replacing starter.
Check for 12 Volts at the locations noted below. Someone will have to work the key for you.
Before you start on the starter make sure you are getting 12 volts to the starter cable that is located on the passenger side under the (Bonnet) hood attached to a bulkhead bolt that is near the hood latch/lock. Then check for 12 Volts getting to the starter.
Good Luck
Charlie Pace
Good Luck
Charlie Pace
RidenXj8 (05-25-2013)
RidenXJ
Look at this forum thread - how to replace Starter Motor?:
https://www.jaguarforums.com/forum/x...r-motor-76686/
Jim Lombardi
Jim Lombardi
KarimPA
09-03-2015 07:32 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
