xj8 tickover
Well, your idle vibration sounds totally normal to me. Are you sure your car has some compression issues? Which cylinders? Tried some thicker oil (sounds stupid but too thinner oil will result in more blowby and therefore less compression) or are your valves leaking?
Workshops like to diagnose things the car doesn't have![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
My former Volvo garage decided that it was time to tell me my clutch was dead and that a new flywheel was needed. Clutch was totally fine. A screw was loose and that tightend resulted in a fix of the problem.
