XJ8 VDP fuel mileage
Wow, that's pretty low....
I get an average of 17mpg in the city, and on a recent 160 mile trip, I reset the odometer, and got a 23.3mpg at a average 75mph of highway driving... Whenever I get high octane gas in Texas (93), I get even better mileage of ~24.5mpg...
Your mpg's are way low....
Have a go at cleaning your throttle body inlet around the butterfly. Next undo the two screws holding the MAF in and disconnect it from the engine loom.
Squirt some electrical contact cleaner in there and clean the sensors, there's 3, one you can obviously see and two up a channel. Once you've done that clean out the part load breather. These three things, along with a hard reset could assist mpg.
If you get stuck have a look in the sticky's in both this forum and the xk8/r forum on how to go about the above, there's pictorals to help you along, it shouldn't take long to do these little jobs, and you should see better averages.
No, you can do it. When you are at a level speed of 50 MPH, the TCC should be engaged. Watch your tachometer as you LIGHTLY push the throttle to slowly accelerate. If you see the tach needle respond immediately to your foot and blip upward, the TCC is not locked. Once you get the feel of this, you can always tell whether the TCC is locked or not. When you crowd the throttle like that, the RPM should not respond immediately to your foot if the engine is locked to the wheels like it should be. By the same token, once you accelerate hard enough, the TCC will disengage anyway for more torque, and you will obviously see that on the tach.
Give that a whirl.
Give that a whirl.
aholbro1
08-05-2021 05:02 AM
