XJ8 VS XJR engine block difference
I have a 1998 XJR. I am planning on purchasing a donor XJ8 possibly a 2002 or 2003. I am planning on doing an engine rebuild due to the fact I have a low compression on one cylinder and I possibly have a the Nikasil liner coating. So I pretty much want to use the engine block of XJ8 and everything else from the XJR. So I would keep the original pistons and rings from the XJ8 what is the difference and would this work or not? Also I will using the original transmission from my XJR to swap over to the XJ8 motor. Thanks
This subject has been beat to death over the years. The amount of time and money involved to perform this sex change operation converting an XJ8 power plant into an XJR drivetrain is not an easy one. Your money will be best used into either finding a suitable replacement engine if yours isn’t repairable, have the XJR engine rebuilt or find another XJR.
motorcarman (10-28-2023)
“98Jagxjr” is simply asking whether the NA (AJ27) and SC (AJ26) engine blocks are same or not. I would also like to know and hope someone will be able to provide the info.
All the 4.0 blocks are same. I have not seen visible differences, the engine manual do not list any of them
and you can see for example here that you can use bare block for any of 4.0 variants XJ8 / XJR / XK8 / XKR
https://www.autoreservejaguar.com/ja...ed-4-0-v8.html
The pistons are dished (to reduce compression) in a S/C vs flat top pistons in a N/A. If he just put the N/A engine from an XJ8 into his XJR (without doing anything to the pistons) with a blower on top with high compression, there’s going be significant detonation unless you run (for example) 100 octane unleaded fuel all the time.
motorcarman (10-31-2023)
