XJ8 Wheel Size Maximum
Sorry for another post, thinking of enhancements to the car, wheels size, these seem to be the max!
4.0i XJR Current Spec. Rim: 10j x 21 ET20 tyres - 285/25ZR21 95Z
Will the XJR fit my XJ8 Ok, and how much space at this size is left between
tyre and suspension strut and tyre and wing arch (fender for our American brothers&sisters)
would 21” 10.5J fit, for the rear ?
jagger98
jagger98
What year XJR is that? 255 appears to be the largest tire width on an X308 from the factory, 275's seems doable with some fender rolling and seam cutting. Unless the car is jack up in the air, 285 might be 10mm too much.
XJ8 rear fenderwells can fit larger tires by rolling the wheel arch and cutting away some of the body weld seam that protrudes about 1" into the fender well. I doubt any tire larger than 255 will fit without doing that, unless it sticks out past the fender lip.
285/25R21 has a outside diameter of some 675mm (26.6"), which is in line with other sizes used by Jaguar on the x308.
For the rear, the tire width should fit with the proper offset of the rim, ET20 as you mentioned should be OK.
You will need to remove the rear bump stop, maybe you can use the later X100 one, or cut the old version in half.
It will be very very close to the fender, and depending a bit of the brand of tires, as they are all different.
For the front though, there is noooo way those will fit without damaging the fender and linings.
AND REMEMBER, the x308 (and the x100 2 door) were the last models using 5x120.65mm bolt pattern, wheels from later models don't fit!
A.J.P (05-25-2019)
I myself think they are way too big for the x308 design, but tried to answer your questions honestly.
To each there own is what you say there, right?
And no to the above question too, will not fit, totally different design.
A.J.P (05-29-2019)
A.J.P (05-29-2019)
