XJ8 to XK8 parts compatibility
I bought a 1999 XJ8 for parts. I have a 1997 XK8. I stripped the XJ8 and sent the body to the crusher. I want to with certainty (yes or no) if the following parts from the XJ8 will fit on the XK8:
-rotors and calipers
-ABS unit from under the hood
-airbags
B
-airbags
B
The only differences are in some of the suspension linkages and exhausts
Hi Brian,
You should be able to get a very good idea about interchangeability by downloading and installing the Jaguar Electronic Parts Catalog from the download section.
https://www.jaguarforums.com/forum/x...uctions-48194/
Follow the instructions in the thread, especially the details posted by Jim Lombardi in post #75, and you will be able to look up part numbers for both cars on your own computer. That should at least give you an initial idea of which parts are compatible.
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (01-23-2021),
MountainMan (12-12-2014)
The following 3 users liked this post by Don B:
juliovega914
11-09-2017 03:55 PM
