XJR = Not a Snow Car
Haha, Atlanta isn't as tropical as you might think!
http://www.wunderground.com/NORMS/Di...=none&IATA=ATL
Even under 50 degrees, the performance of summer tires is severely diminished.
In Ireland we don't have too much call for snow tyres (most years go by with no snow at all). However, when there is snow, it is highly effective to put a couple of sacks of sand in the trunk; this increases traction for the rear wheels. It really makes a difference.
Of course nothing helps on ice-even iffy with chains. I just totaled an 02 VDP in January. Ice I did not could not see until I was on it at night. Roads were clear for miles but apparently this slight downhill is in the shade so didn't melt off. Just recently replaced the 02 with a very nice low mileage 04 XJ8. Even with snow tires on any of my cars I have always put some weight over the rear tires in the trunk. Like our Irish friend says it helps. Also if you were to become stuck you can always break open the sand bag(s) and put the sand under and around your tire(s) and drive out. Not a bad idea with the even with the best of snow tires on your car. Also not a bad idea to carry a small collapsible shovel in the trunk.
Another thing...I don't drive the Jag in the snow. I drive my truck now. Just happened on that particular night I could not drive the Titan as it was out of town with my wife. Biggest hurt was my feelings....I had not control solid ice for about 200 feet in both lanes. It was what I call one of thos Aw Sh-t moments where all you can do is hold on for the ride.
Bill
Bill
I'm in northern Indiana, 7 miles from the Michigan line, and we get lots of snow. I put Dunlop winter sport tires on my 99 XJR and have had no problems. Of course, I drive sensibly in poor conditions.
The OP obviously was not expecting ice or he wouldn't have punched the throttle (I hope). Releasing the throttle in the middle of a curve will also give you nasty lift in the rear end and possibly put you out of control. Moral - be aware of weather conditions and always try to anticipate the unexpected.
What I thought of doing (should I end up going to a university in the north) is going on CL, and buying an old set of 16" wheels from an XJ6 or Vanden Plas, and then just putting those wheels on it for the winter (snow tyres for my 18"s are insane, they don't even seem to make them!--Too spensive) So I could have a set of winter wheels with no worries about curbing the hige wheels it has, and in the winter have better traction (and more fun on summer tyres).
#30
I was disappointed to find this out as in the past I have usually gone done a size or two for winter wheels and tires..
#31
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
#32
Of course, you could just pick a university in the south from your neck of the woods to So. Cal. and generally that should take care of it. I think Arizona and So. Cal. are the only sunbelt areas other than Southern Florida that didn't get snow this year!
BTW, great looking car you have there if I do say so myself!
#33
Not sure if you have a XJR or XJ8, but if you have an XJR, you will not be able to go smaller than 18" because of the size of the front brakes (non-brembo)..
#34
#35
#37
The 16"s will fit on my car, its has got large brakes but I'm confident they are the same as the XJ8's brakes, so 16" will fit ok. And I found a nice set on orlando CL for like 200$. and those were on decent goodyear all-seasons (well, no such thing, but ok tread) and were from a Vanden Plas. Plus, in addition to them being narrower (ergo, better in snow) They are also not going to get curbed in an icy parking lot. And I'm fairly sure my brakes are XJ8 brakes, but they seem very large-maybe the sport got a brake upgrade. Oh and nice car yourself, MidlifeXJR-good choice of wheels and colour lol
#38
The "beater" is my 1991 Sierra Ext. Cab Z71 with the 6.2 diesel with an old coach conversion leather bucket conversion. Even with a foot of snow on the ground I rarely have to use the 4x4. The biggest benefit is it keeps the salt off my good cars. I HATE road salt.
I named it Chuck Norris.
![Name: z71diesel1.jpg
Size: 70.7 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/174113d1501291497-xjr-%3D-not-snow-car-z71diesel1.jpg)
#40
The two issues with the XJR chassis are the extra-wide tires and the relatively non-compliant suspension system; both of these issues tends to give incredible dry grip but the chassis rarely hunts for traction.
I have 245/50-17 Dunlop winter tires on 17" XK8 wheels on my XJR and they are still too wide to cut through any amount of Canadian winter deeper than 3".
Solutions: maybe get even narrower tires with very deep tread. Tirerack recommends 225/55-17... SP Winter Sport 3D should do the trick next winter.
![](http://www.tirerack.com/images/tires/dunlop/du_sp_winterspt_3d_ci2_l.jpg)
