XJR 100 wheel and caliper refinish
Old 05-23-2021, 02:31 PM
Z07Brandon's Avatar
Default XJR 100 wheel and caliper refinish
Looking to get the 4 centers redone, and all 4 calipers. Wheels I want to get redone in the factory color, but brushed. The wheel bolts, I will buy the gold plated ones. Plan to get the "bbs" lettering painted red. Anyone know what the paint code is for brake calipers? Also, where can I get the red jaguar lettering for the calipers? Is the "jaguar" clear coated over the caliper, or just stickers? As you can see, my centers and calipers could use a refinish.
Wheel trims. I know the 19inch trims are basically gone. If I remove them, and polish the lip of the wheel, will they look smaller visually?
EDIT: I already have new center caps. Oem red caps.
Was going to buy some 2 piece aftermarket wheels, but decided against that.
Old 05-23-2021, 05:42 PM
Addicted2boost's Avatar
Received 1,033 Likes on 813 Posts
This is all I got to help you with.
Z07Brandon (05-23-2021)
Old 05-23-2021, 07:01 PM
clubairth1's Avatar
Received 2,351 Likes on 1,851 Posts
There are a lot of options on EBay for vinyl stickers. Either Jaguar or the leaper.
I used white Jaguar letters with my red calipers.
Old 05-23-2021, 10:52 PM
Z07Brandon's Avatar
Sweet. Thanks guys. I'll post pics when it is all done.
Old 05-24-2021, 10:08 AM
clubairth1's Avatar
I forgot but I just replace the center caps when they fade. So many colors on EBay. They are not as tight as the factory center caps but with a bit of tape you can snug them up.
I also sprayed clear over the vinyl to help make it last. I just got red caliper paint in a spray can and did them on the car after masking them off.
Seem to be holding up after I replaced the factory dusty brake pads with Porterfield pads.
Old 06-26-2021, 10:23 AM
Z07Brandon's Avatar
Anyone know what we torque the wheel bolts(not the lug nuts) to?
Old 06-27-2021, 01:38 PM
XJR-100's Avatar
Searching for this spec can be daunting but the consensus seems to be between 12 & 15 ft/lbs with blue loctite. This also acts as a torquing lube so I would not approach the upper limit. Probably more accurate if you convert to inch/pounds and use the appropriate torque wrench as our regular wrenches barely work at anything less than 15 ft/lbs.
Z07Brandon (06-28-2021)
Old 06-28-2021, 07:28 AM
Z07Brandon's Avatar
Thank you very much!
Old 06-28-2021, 11:39 AM
Back when I was refinishing the Montreal’s and getting another replacement wheel, I asked sbwheels what I torque the barrel spline bolts to and he said 11 ft lbs. I’m sure he told me in Newton meters but I just converted it to ft lbs. Anyways, I’m not trying to add confusion or contradict what XJR-100 is saying, I’m just going with what I’ve been told. I still have mine to 11 ft lbs with Loctite blue and have had many happy trouble free miles on them over the years.
Old 08-02-2021, 03:30 PM
Z07Brandon's Avatar
Finally have some time to work on my cars. The 100 is on jack stands so I can get the centers redone. But of course, the wheels are like welded and won't come off the rotors.
Old 08-02-2021, 04:59 PM
Jhartz's Avatar
HT Blaster around the hubs and let them sit overnight. You may need to hammer them off to break the rust and corrosion . . .
Old 08-04-2021, 04:06 PM
Z07Brandon's Avatar
Yup, my dad helped me hammer them off. Luckily no Ti bolts stripped or cracked. But I did buy new gold plated bbs bolts.
Addicted2boost (08-04-2021)
Old 08-05-2021, 11:08 AM
clubairth1's Avatar
Good job! I bet all those small nooks and crannies around the bolts are real fun to keep clean too!
Old 08-05-2021, 11:10 AM
Z07Brandon's Avatar
They are! But I'm a detailer, so I enjoy it. Just dropped off the centers. Getting them brushed with gloss clear.
Old 08-05-2021, 01:55 PM
Dirtboy Nay's Avatar
Hi Brandon. A How to Disassemble Prep Paint and Restore Jaguar 2 piece BBS Milan, Detroit Montreal etc. DIY Restoration would be Appreciated. Detailing what to do & what to avoid in the process. If you'd be so kind, share your knowledge and experience .
Dirtboy Nay
Old 08-06-2021, 07:16 AM
Z07Brandon's Avatar
Bolts arrived quickly from the UK!
Well the centers off is easy, but tedious. I wouldn't use power tools when loosening all the small bolts. Socket you'll need is an M8 Spline drive. I know the gold bolts isn't everyone's taste, but I love them. I'm removing the trim rings. Can't find any new ones, and mine are pretty nasty. So, I'll be polishing the actual lip of the wheel.
Old 08-06-2021, 08:36 AM
Even sbwheels didn’t have any of the trim rings?
Old 08-06-2021, 08:49 AM
Z07Brandon's Avatar
I'll check, thanks
Old 08-06-2021, 08:53 AM
Originally Posted by Z07Brandon
I'll check, thanks
It’s only post #2 on here. 😄😄
You must gloss right over everything I say like a lot people do on here. 😂😂
Old 08-06-2021, 09:06 AM
Z07Brandon's Avatar
I'm a certified fool🤣😎
Quick Reply: XJR 100 wheel and caliper refinish
