XJR 1999 air conditioner
hi guys...
I have a question about my car.
When I turn off the A/C and the car is running, the fans are still working.
(If I dont use the A/C the funs only work when the temperature goes up.)
(My car doesn´t have temperature problem)
Is this normal or my car has some problem?
That just turns off the AC compressor but not the rest of the system, like heater and fans. As long as cabin temperature is lower than set temperature, the system will still attempt to heat the cabin to reach set temperature. Depressing the fan button turns the entire system on and off.
Ah! Not understood from first post.
I suspect (but don't know for certain) that the cooling fans will remain on for some time after the AC compressor is turned off in order to continue cooling the pressure heated freon in the condensor.
One with better knowledge may be able to answer for sure.
