xjr 2000 ignition control module
Hi Guys , Having a bit of a no spark problem , I would like to find the location of the ignition control module . in the manual I have its tells me its in the servo compartment ,but alas nothing. ............. there are no codes , there is voltage at the ignition coil relay , hoping its not the ecu.
thanks, Phil
thanks, Phil
targahs1 (10-13-2015)
I would suggest testing the hot lead to the coils. have a look at the diagrams, or check back if you need help IDing the power supply lead. 12 v power is applied to each coil and is switched through the amp to ground. You may have a fuse or relay problem. Few, if any, ECU problems with your symptoms are reported.
Phil:
There is an amplifier inside the coil. The power to the coils is the Red with white stripe (at least according to the diagram for a MY02). It is fed from the ignition relay (em26) in the ecu compartment. So are you saying the coil relay is not pulling in? I am not sure, but I suspect the inertia crash switch turns off the ignition relay.
So... what happened just before you lost spark?
The following 2 users liked this post by Jhartz:
RJ237 (10-14-2015),
sparkenzap (10-14-2015)
Hi Guys ,Had to leave it alone yesterday givng me a headache ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
The main problem is I live 120 miles from the nearest Jag dealer and I hate to trailer my cats.
The trouble started as I was pulling out of my garage. I stopped to
answer a text for maybe 2 minutes , and it cut out. A message came
up "engine stalled" . I've thought about flooding , but thats not it.
So far I've bought crank position sensor, maf sensor and temperature
sensor. Still no spark , voltage at relay , none at coil. Today im gping to clean every
connector i can find . Bought a ecu from ebay uk payed $175 inc. shipping
i know you are surpossed to get them flashed, but maybe ill get a spark.
Found the ineracia switch and it was in the down position.
Thanks, Phil.
Thanks, Phil.
Unless you are giving wrong info about the ignition relay, you are wasting your time looking for bore wash, plugs compression or whatever. The supply from the ignition relay to the coils on the red/ white wire should be 12 volts to ground. The ground lead is the black wire, but the chassis should be the same. IF YOU DON'T HAVE THAT, THE ENGINE WILL NOT RUN. And, again, what do you mean voltage at relay but not coil? A conductor (wire) runs from the relay to the coil, so what you say makes no sense unless the wire is broken.
Unless your info is bad, I cannot understand the attraction of working on other stuff when you have defined an ignition problem!
