xjr 97' v8 fuel trims is this good or bad?
Hello guys , ive got a tip to put the fuel values on the forum. Im having some problems with starting the car 6 out of 10 times it starts not good takes from 3 to 10 sec and then it starts batt is good and starter to . But sometimes it start right up no problem and when use kickdown at low speeds it starts shaking and holds back this is also when driving around 140kmh and making around 3000 rpm . So ive got this info :RPM 645 .in park idile short term bank1 : 0,0 long term bank1: 10,9 short term bank2 : 1,6 long term bank2: 5,5 Maf : 5,0g/s inlet temp 11degrees celcius . Now at 2522 Rpm short term bank1: 2,3 long term bank1: 8,6 short term bank2: 2,3 long term bank2: 3,9 Maf :17,4 i hope you guys can help me out if this is good or bad and why or what could cause this. The car had some mods lowwer and upper s/c pulley change electric coolant pump upgrade Thanks
With checking this i got 2 codes p0335 and p1230 cleared these and did not came back . Ive checked the sensor and fuel ralais earlier so the codes could come up when i looked at this so i dont think these are the problem so if you sit in the car is bank2 the left or right side of the car ? And a vac leak must be after the supercharger after that the intake split and go trough the intercoolers and injectors to the head. If both banks were not ok the leak would be at the supercharger or elbow ,throttlebody ,intakepipe , or am i wrong ? This trouble happend after a week i changed the chains an tensioners and rebuild s/c it ran good for a week but then got problems so maybe a gasket is bad could be but ive checked with carb cleaner for leaks but then could not find one. But this info shows there is something there.
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
