xjr 99 ,how do they air conditioning fan work
Tanngo, I understand you are having problems communicating your question, english I am assuming is not your primary language. I'm even confused trying to figure out what you're asking. Don't worry or be frustrated, we have alot of foreign speaking members here.
I've deleted your two posts following your first one (to keep it simple)...you can edit your original (look in lower right corner of your post), maybe ask for some help in translating exactly what you need, and try again.
Best of luck.
Best of luck.
copied from Google translater
I'm pretty sure thats normal. Running the A/C puts more stress on the motor and creates more heat than w/o it, so the radiator fans may kick into high speed for awhile, and even run after you turn off the car and it lowers the temperature to a predetermined point.
You do mean radiator fans, not the internal blower fans, right?
How It Works Tell me air conditioning fans, when I turn off the ac, fans are still ongoing, only if I turn the car off and completely cooled.
traduccion mejorada ...
When I ignite air conditioning with the car in march they ignite ventilators, when I extinguish air AC ventilators continue running I want to know if it is normal that the ventilators continue running with the subdued(switched off) AC and the car in march ... in my ex-mercies benz when AC to extinguish, ventilators extinguish..
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
