xjr brake pad clip
Mine has them on all four corners. I've also been known to forget the dumb things when doing pads from time to time and remember a week afterwards when I see it in the tool box. It's not going to do anything to not have it other than a little rattle perhaps, but yes, there would usually be one on each caliper.
xjfourty (08-24-2018)
where may I find it ? something like rockauto ?
I found these, according to rockauto they should fit for a 1998 xjr rear brakes
https://www.rockauto.com/en/moreinfo...315913&jsn=407
The Rockauto items look correct, but I'm unsure what model Jaguar you have, your post says XJR, which I believe has Brembo brakes, but your pictures look like standard XJ8 brakes. And you list your car as also being a 1996 XJ6, so maybe that is what you have?
But I think the caliper clip is the same part number, here are links to forum sponsor SNG Barratt, they list the OEM part as JLM12122
https://www.sngbarratt.com/us/#!/Eng...20CALIPER-REAR
texevora
10-31-2015 08:43 AM
ryejag
10-20-2012 06:42 AM
mooreman6
01-06-2010 03:18 PM
