XJR cooling issue v8. Running hot. Any help or input appreciated
Hi All,
First of all, happy newyear.![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
After rebuilding the engine i'm stuck with a cooling issue and I can't seem to solve it. Any help is much appreciated.
The following is the case. The fans are not kicking in even with the temp (real gauge) moving well past the 3/4 mark.
I've replaced the temp sensor, thermostat, coolant, and the fanrelay. Also checked the fuses. When I turn on the ac then both fans do rotate. If its off, fans are not running.
I've also get the idea the thermostat doesnt open at all, as the driver side hose doenst get warm. That would indicate it won't open, or not?
Maybe i'm being to carefull not to have the engine get to hot. I just don't want to ruin my freshly rebuild engine....
On a side note I also get the limited power message on the dash. ALso there i really have no clue what is causing that. All in all some strange things going on, and me being a beginner in the jaguar world I can really appreciate some help from the community to get this solved.![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Thanks so much!
Jeffry
Thanks so much!
Jeffry
Ah ok thanks Mark. So where is that sensor located then in the radiator? I havent conciously seen it nor plugged it in. I'm only aware of the top coolant sensor on the thermosatat housing.
Will the circulation not function fully when not driving the car? I haven't been able to drive it on the road because its suspended....
If the temperature gauge is reading high, and the radiator is not getting hot, there is a serious problem with coolant circulation.
Reasons I can think of :
The radiator is blocked.
The thermostat is jammed, or in backwards.
The water pump is not working. (belt not installed properly, impeller broken?)
The system has an airlock.
sparkenzap (01-01-2016)
+1 Mark.
Air lock in the cooling system is one check to make. Did you turn the heat up to full after refilling the cooling system? Did you remove the plug at the top of the intercooler? Try pumping the upper radiator hose to burp the system with reservoir cap off.
I don't recall if the XJR has two bleed lines out of the tank. If so, they should be crossed.
Pull the thermostat and check for correct operation in a pot of water. I put a new thermostat in mine during a rebuild; said 84c on stat, didn't start to open till 92c. What sort of coolant did you use? Might be worth pulling off bottom hose to see what comes out, as regular and long-life coolant aren't compatible; can form sludge.
airtracker (01-16-2016)
I got the random overheat cured and am now getting random low coolant messages. The coolant level is good. I even made sure there was no air in the system. Turned out the problem with the raditor fan was a bad connector on the fan. Not fully seated, high resistance excess current poof goes the fuse. Now have 2200 miles with out loosing a fuse. I have checked the electrical guide, and other than a bad sensor, can not see any reason for the random fault. OBTW the sensor is only 6 months old.
adpock
F-Pace (X761) / C-X17
08-22-2016 09:22 PM
uncheel
12-15-2015 06:37 PM
