xjr diff mangled
I got a diff delivered in the usa for 270usd, and a propshaft for 190 usd. Eat your wheaties before you do the job. The bolts are big and tight and the parts are heavy. As for the any diff issue, there are really two different ratios, a 3.08 and a 3.27. While I am sure both will work, I made sure I got the correct one, which was a 3.08 on my 2003 xjr r1, because I was worried about a gear fault putting the ecu into limp home mode if the wheels were not spinning at the speed the ecu thought they should. Maybe somebody else knows if it makes a difference to the ecu, but I played it safe. I would have rather had the 3.27, but settled for what it came with.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
