XJR fuel injector specs?
I guess no-one has ever removed the injectors from a supercharged engine.
I got the E85 piggyback system, but the gap between the valve cover and the cooler is too tight even for the injector connectors to come through... I'm planning to have the tensioners and chains replaced soon anyway (and perhaps upgrade the lower pulley too), so I was thinking about having the injectors replaced with bigger ones on the same go...
Does anyone know if those 550cc injectors are available anywhere in Europe? I guess Buckhead can ship them over, but I'd rather avoid paying the extra taxes.
Avos, are those 4.2 injectors a direct fit?
Price of regular gas is on the rise again here, and it's getting easier and easier to justify the cost of bigger injectors...
There is an adjustable E85 conversion kit that allows you to do just that. It also has a few presets, so you can change between fuels by pressing a button if needed.
Bioadapter E85 conversion kit
Charlene n John
09-28-2015 06:01 AM
al_roethlisberger
09-07-2015 10:53 PM
