XJR Goes to the Drag Strip!
If your car is stock, the time is very normal. Try again when 50 degrees and use low tire pressures - you will get 13.8/102, which is standard for the stock cars.
Mine is not stock.
You can find some results from here: Fast Jaguar XJRs 1/4 Mile 0-60 Drag Racing - DragTimes.com
I use mostly Shell V-Power, but nowdays there are not very much differences between 93 ( in Europe 98E ) fuels.
aholbro1
08-05-2021 05:02 AM
