XJR Help Please!!!
Guest
Posts: n/a
My 1998 XJR is crapping out on me...The Car runs fine but a little rough at times. If you let it run for a few minutes,coolant/water will poor out of the front of the motor,(could be a water pump problem that started this in the first place.) This car is way too new for me as i am used to working on Carburated cars.....I hope this isnt the nikasil thing people are freaking out about!!!!It does have white smoke coming out of both tail pipes, every now and then. Any help would be greatly appreciated
Cheers!
Cheers!
I had a similar problem with my 1999 XJ8. I had coolant running everywhere and at first I could not trace the leak. Odds are either your thermostat housing is shot (it's a composite plastic) or the bottom housing seal has failed. Best thing is to remove the plastic ornamental covers that go over the valve covers, start the engine and see where the coolant is spraying from. The thermo housing is the tall black thing sitting at the front of the engine with hoses running into it. The housing cap is flat and round with a slot for a 10mm Allen wrench. You can also check around the base of the housing with the engine off and see if there is coolant in the depressions right next to it. If so, you have probably found your problem. Mine started spewing with no warning.
If that is what your problem is, I can give you a complete parts list for the job, plus a couple of tools you will need. You will probably want to replace the housing, thermostat and all the associated gaskets and caps, as well as the coolant rail. All the parts for the job cost me about $175 from Motorcars, Ltd. (http://www.motorcarsltd.com). The job took me about an hour to complete and after having done one and having all the tools on hand I could probably cut 15-20 minutes off that now. It's not a hard job (the dealer wanted a grand for this job).
Orca, his car is supercharged and is configured quite a bit differently.
Gavin, your car is not user-friendly when it comes to repairs. Your time will be better invested if spent looking for recommendations from Jaguar owners in your area who have a trusted mechanic.
