xjr issues please helpppppp give me some advice thanks
ok here it goes
recieved me xjr yesterday guy i bought it from said it had issues but didnt know what somthing about limp mode
well today i got in and started it up after it was sitting for like 3 or 4 months i think at the guys house
it idles rough probably needs a good tune up
but when i try to rev it wont go past 3.5k rpm
when i put it in drive i give it gas and nothing rpms wont go up or anything its like it doesnt wanna accelerate at all just sits there
once i put it in parking i can rev but only to 3.5k rpm please help guys
what could be the problem
Normal that it won't rev higher in park or neutral because that is the way it is programmed . Sadly, sounds like your transmission is finished. Hope you got the car for a pittance!
________
Wellbutrin attorney
________
Wellbutrin attorney
i got the vehicle for 2000 bucks which is not bad has 106k miles and it looks great no dents or no major scratches interior looks clean
i got some other questions what the best items to use for the engine
spark plugs
engine oil
air filter
transmission oil once i get it replaced called a shop and its close to 800 bucks to get is fixed
thanks again guys
spark plugs
engine oil
air filter
thanks again guys
Is the Check Engine Light on ? If so what are the codes ?
You've already had the heads up about the 3.5k RPM from Markus. But the other issue you describe (ie put it in drive and it only trickles forward, no matter how hard you push the gas pedal) is how the car behaves if the engine goes into "Failsafe mode" but you would be getting this message in the message centre. Any error messages on the message centre ?
For what it is worth I had a similar problem with the 1999 XJ8 I got.
Failsafe mode message was on, wouldn't go over 3K RPM (as designed). Tried to move it in drive and it move a little but eventually would stall out.
Code scanned it and it reported a misfire on the #8 cylinder. I took the fuel injector out, which the pintle cap came out in pieces. Bought a new fuel injector (not cheap), put it in and engine problems went away (although a bunch more has come up since :-) ).
Guess what I am saying is code scan it before you panic about the transmission. If it is in failsafe mode I have to believe there are codes in there.
Transmissions $$$
WJGESQ
got some codes
p1000
p0750
p1797
also when i pulled the transmission pan of and the valve drive there were metal flakes and at the bottom of the pan when i ran my finger across it was all grey probably metal
working on taking the transmission out a lil at at a time found a guy who is going to rebuild it for me for 800 bucks with 12 month warranty cant beat that
p1000
p0750
p1797
Received 2,263 Likes
