XJR J-gate shifter issue
Question about my '03 XJR. I've had the car a couple months now and for the first time tried to slide the shifter over from Drive to pseudo-manual and it won't slide over and out of 'D' no matter if I'm stopped or driving. Is there a trick I'm missing or do I have some linkage issues? Probably won't use the "manual" mode much, if at all, but I'm curious as to what's up.
Thanks,
Kevin
Milwaukee, WI
Thanks,
Kevin
Milwaukee, WI
It normally slides over very smooth. Here is a problem to check that I have fixed in the past on both and xjr and xkr. The dust/dirt sheild that rotates with stick (round plastic plate with plastic black toothbrush looking bristles) sometimes will crack someway or another and it jams up the manual side of the j-gate. Look down with a flash light while moving the stick (with key in ignition and car not running) and see if you can see a physical obstruction. It will look like your stick is hitting a black plate where it seems it should slide to manual mode. If that is the case, remove gear knob, remove the trim, unscrew/bolt mechanism and usually the broken guard will slide out with some tinkering and luck. From then on don't eat any everything bagels around the j-gate because there is no more protective barrier to guard falling poppy seeds
