XJR memory seat problem??? pls help
hi everyone
i have 2000 model xjr but recently when i enter the car and put the key in the seat does not move forward and when i take the key out the seat does not move back...
also when i press memory button 1, 2 or 3 it wont move to set positions, however the buttons on the seat do work and move the seat to desired position now when....
i do that and i take the key in or out the seat moves until and i say until i lock the car with remote after that its back to square one...
this happend for the last couple of weeks,
what could it be? remote? memory seat buttons on the door???
thank you for reading appreciate and replies ans sorry if i have confused anyone...
regards
regards
The first easy test is to swap the seat modules found under both the driver and passenger seats. There is also a control module in the driver door and the body control module to consider.
But first, do a cold, hard boot of all the systems by removing the negative terminal off the battery, touching the cable end to the positive terminal of the battery and then reattaching the cable to the negative post.
The car's electronics are also sensitive to battery voltage. Make sure you have a good battery, properly charged.
thank you for reply a few questions the control module in the door how can i test if its defective or not? and also is the body control module in the door aswell?
also is what should a good batter read with a multi meter/volt meter to determine whether battery is good or not?
and thirdly am i right in thinking you said take the negative cable on and touch it to the positive terminal and the reconnect the negative cable?
only asking coz i dont want to do anything wrong and cause an explosion...
thank you for your time and help
regards
regards
Leave the positive cable on the battery. Touch the negative, ground, cable to the positive post. That will drain all the little capacitive voltages out of all the electronics.
A charged battery should read 12.6v plus or minus. With the engine running it should measure 14.5 plus or minus. The electronics do not like voltages below 10.0 even if the starter will rotate the engine.
There is a module in the door, another under each seat and the BCM is in the dash. After the battery it is on to the module in the door as most likely villain . Connection or defective.
ok cheers mate first i'll check the battery voltage and then i will do the hard reset like you've instructed...
hopefully that works if not i will move onto the control modules ... i'll keep you posted thank you your help...
will have to learn hot to gain access to th door module ones under the seat should not be too much of a prob....
regards
regards
also test point just wanted to quickly ask you, i use the car lets say once a week and i noticed after putting in mobil 1 esp oil 5w 30 when i start the car it gives out a blueish smoke for about 5 seconds after that its fine, drives fine no smoke etc even if i start it a few hours later no smoke at all and instant start, its only after a week the smoking happens when fired up?
is that bad or very bad?
cheers
cheers
ok thanks for reply guys so this smoking on start up wont require a head gasket or rebuild???
going to have a look at the modules on the weekend keep you all informed,
strange things happen i tell ya, few days ago i thought i imagined it but today it confirmed that sometimes randomly one of the doors will unlock, i return to the car and will see one door pin in the up unlock position...
wonder if this has anything to do with voltage or one of the modules????
regards
regards
So, after checking the battery, its a fast check of connections, door card off, check module wiring loom all the way home, same with the seat, and check all the wiring you can see at wear points.
________
herbalaire vaporizer
thank you very much everyone, sean B i think you have made my job easier those are the steps i will follow, did a voltage check have not used the car for a week and the voltage is reading about 11.40v so i am not sure if that is low enough...
next will be me following your guidance and everyone else...
keep you posted
regards... p.s is 11.40v reading low???
thanks
keep you posted
thanks
hi guys right...update...
it was the voltage, so because the car only gets used in the weekends or every other weekend it dropped voltage and seat and memory would play up...
so i'm happy its not the modules or switches etc...
as for the blueish smoke on start up, yes i guess like you both said a little oil seeping when i used the car say the next day instead of letting it sit it would hardly smoke...
so i guess the poor car does not like to sit and mope around it likes to be kept busy crusing or racing...
just like to say thank you for all your help and advice...
couple of things before i go...
interior light near the sun visor you got the switched map light button, interior light button, map light button...
now those button illuminate the writing... i.e map is illuminated...
well one of my map button is not illuminated any ideas how i could change the bulb? is it a bulb or is it the whole unit?
petty but i want this car to be 100% well close to it...
cheers
cheers
Try changing the bulb. It may require removing the upper console housing. To remove the console, open the sunglass holder and you will find a plastic fastener that can be turned with a flat head screwdriver. You only need to turn it a quarter turn to release the housing. Console will fold down. There is one connector to release if you want to completely remove the console.
Replacement Bulbs
This bulb us used all over the car. I have found it at my local auto parts store here in the US. From OSRAM Sylvania's websites:
OSRAM Sylvania
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Parking light
High mount stop light
Front sidemarker
Map light
Step/Courtesy light
Under hood light
OSRAM Sylvania
2825
Parking light
Front sidemarker
Map light
Step/Courtesy light
Under hood light
Just realized that this could be more like an instruement light, if you are talking about the light that actually lights up to show "map" when the map light is not being used. If so, it may be OSRAM Sylvania 2721 or 2821 / Instrument General. Available online at Advance Auto Parts in US. Should be available in UK as well.
