XJR needs help !!!!
well it turned out that there was a loose connection in the engine bay. the plastic around the contact point begun melting, I replaced the bolt and made sure that it was a tight connection. The generator output measured at the battery terminal seems right where it should be and even the starter cranks with vigor!!. so far so good......thanks for your support guys !!!
