XJR needs help on emission readiness
Hello guys, my 1998 XJR failed emission test because "The emission readiness test wasn't completed". I scanned the OBD and found P1000, which means the readiness test has not been completed. I've been driving the car for a couple of days and the check engine light's still on. what should i do to complete the test? I really need your help on this!!!! thx
Something does not quite add up- P1000 does not turn on the CEL. So, what does not add up is that you say you have the light and no code besides P1000.
What happens is, when you reset the codes, P1111 changes to P1000 until the OBD drive cycle completes, to test whether the car has emmision issues or not. That is so simply resetting the codes will not make the car appear OK when tested. If the car cannot complete the drive cycle, then the P1000 will not change back to P1111. You need to figure out what drive cycle test is not complete, Scanners that read "OBDII mode 6" tell which tests are complete and which are not. However, again, I do not believe P1000 should light the CEL by itself.
edit by JagV8: you do not need mode 6 to see which monitors have set (completed) - any half-way decent generic OBD tool will do
amha07 (03-26-2011)
amha07 (03-26-2011)
Thx a lot guys !! I've already purchased a new pump for the jag but I thought the second pump was a spare and decided not to replace the malfunctioning pump. now i know there is no any other way to pursue this issue. I really wanna thank you again for your tremendous help. you guys r awesome !!
amha07 (03-26-2011)
Col. Sandurz
09-28-2015 12:49 PM
Ipc838
09-13-2015 03:27 PM
