xjr no start
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Im stuck n wondering which direction 2 take i got a 99 xjr...shut off going down the road got it home found no spark had a code p1336 put in a new cam sensir on the left side head rechecked for spark and no i got spark but still no start. In stalled new spark plugs old ones were fouled out but now after i crank it over u can still see the gas on the tips the only code i got now is p1000...
new 2 the site thanks 4 any input
Yes you could have a cylinder wash problem but I would check the fuel pressure first. The pressure should be 42 +/- a few. Please check it to be sure. My neighbor told me that he had fuel and proceeded to show me. He opened the valve on the fuel rail and fuel came out but not with force. Put my gauge on it and found low pressure. Replaced the pump and he was back on the road again. You say you have spark and no other codes is that correct?
Well, when I have spark, compression and fuel pressure, the last thing to check is if fuel is getting to the cylinders. If I were in this position, I'd spray some starting fluid through the throttle body and see if the engine trys to run for a second or two... if so, you know that somethings up with the injectors.
But I don't think you've checked compression yet, have you? Compression gauges are quite inexpensive. Nikasil washdown or a timing chain issue will show up in a compression test.
hunter34
19
09-14-2022 11:09 PM
