xjr oil leak
There isnt very much oil along the gasket line of the cam cover but lots on the injection wiring and injector plugs and loom support rail and along the underside of the cooler. the last issue it had was a borewash non start which was sorted by lifting light oil in a tube and blowing it down each bore, sorted it immediately, but never got a long run til last week, 600 miles and the only problems being this annoying leak and white lines tugging at the steering! The only thing in the back of my mind is that it had an engine change because of an overheat and holed piston, not sure if the coolers were checked for oil from that trauma or if the new engine kept its own coolers! It was the left bank that had the problem!
1964Daimler
10-04-2016 10:02 AM
