XJR overheated
My 2002 XJR - Day before yesterday I noticed that the auxiliary fan kept running after I shut her down, which is something it never does, although it did shut off after a few minutes. The ambient temp was only about 78 deg. and I had checked the coolant level only a week ago. But yesterday it overheated on me. When I was able to open the coolant cap I noticed no visible coolant inside, but neither have I seen any indications of coolant leak, like on the floor, unless it only loses it during driving. I thought perhaps the water pump, but in my experience bad water pumps always leak and this one isn’t. Or is it worse, like cylinder pressure sneaking into the cooling system through a rip in the head gasket? Certainly need to do some tests.
I’m open to suggestions.
Thank you
Thank you
Forcedair1 (09-26-2017)
Thank you.
Cheers,
Thank you all fellows for the feedback, it will be the thermostat first. I'm surprised at how easy and accessible the X308 thermostat removal is on this YouTube clip. Will hardly even lose much coolant.
BTW, is there a "better" or improved thermostat that I should rather get for this application?
Thanks for the info.
Cheers,
Cheers,
The following 2 users liked this post by RJ237:
ericjansen (09-25-2017),
One more question, where do I find the "header tank" and the access to it? I still can't tell from all these denominations, why so many names?:
-- Expansion tank
-- Header tank
-- "Fender" tank
-- Recovery tank
Which one of these is the one by the windshield next to the brake reservoir?
One last question... Can somebody tell me what is the specific reason why these cars cooling system need bleeding, or when? I've never heard before about having to "bleed" the cooling system in any of my cars, including my XJS.
Your feedback is much appreciated.
Cheers,
-- Expansion tank
-- Header tank
-- "Fender" tank
-- Recovery tank
Cheers,
One more question.
I've never heard before about having to "bleed" the cooling system in any of my cars, including my XJS. Can somebody tell me what is the specific reason why these cars cooling system need bleeding?
One more, where do I find the "header tank" and the access to it? Somehow they seem to have skipped that info on the manual I have.
Cheers,
Cheers,
It's referred to as the 'coolant exapansion tank' on our cars, sorry for the confusion!
Well, the culprit was certainly the thermostat. Upon testing, the warming water pan came up all the way to sea-level boil temp (100 C, 212 F) and the old thermostat never opened. Conversely, the new one began to open at around 84 C. I also replaced the 100K-miles-old filler neck cap (the car's about 75 miles from reaching 100K). Topped off the fluid and went out for a drive with the needle glued exactly in the middle of the gauge's range once it warmed up. I guess that reaching boiling temperature for a real short time didn't necessarily cause any damage (warp) to the head joint surfaces. The engine ran very smooth and powerful as usual and certainly no leaks.
Inspection of the system's hoses, including the intercooler hoses, reveal that they don't look necessarily bad, considering that they are all the original hoses in a 100K-miles car. I also did notice how unusually easy to access and to replace they are, including all the intercooler hoses. I'm certainly going to purchase the majority of these hoses and get them replaced all at once for piece of mind. I wonder what else in the cooling system should be replaced at these many miles. Belts wise, the main serpentine belt was replaced about 1500 mile ago.
All your feedback and comments are much appreciated.
Cheers,
Cheers,
BTW, I bought my thermostat from the local AutoZone store for $11.99, including the seal, plus the "radiator" cap at $13.99 and a gallon of the Prestone Dex-Cool antifreeze for $16.99. The parts carry a 1 year warranty. I'm pretty sure that these parts (made in Germany and Israel, respectively) should be as good as whatever quality the actual Jaguar parts may be. There should be Autozone stores in Dallas, or similar.
The great thing in this case is how easy and accessible the parts are to replace, considering that we have a supercharger with its intercoolers right there. Even a water pump replacement appears to be not that complicated as per my service manual, and again, in spite of all the supercharger components in the way.
Hope your problem is resolved in a routine, easy manner and with no complications, like mine luckily (and surprisingly) turned out to be.
Cheers,
