XJR overheating problem
Wow, that's kinda hard to do and not have it leak. My thermo has an intergrated rubber gasket that fits into the groove in the housing. It's almost kinda impossible to install this backwards.
Some model years (i dont know if all) came with water pumps with plastic vanes, which can sometimes break off apparently. I did mine at 98k and the impeller looked very good, though I don't know if it had been changed before. You can replace it with a pump with a metal impeller and leave it for probably the lifetime of the car..
omgimali (11-21-2016)
#30
#31
I just replaced mine.
The vanes still looked like new, but the bearing was tight and made some noise.
A replacement Airtex only runs for ~$33 at Rockauto, a no-brainer.
More Information for AIRTEX AW4124
