XJR plastic timing chain tensioners
Even though this is the wrong forum, this is not true. Your tensioners on a '98 XJR should be upgraded ASAP to avert potential engine self-destruction.
JimC64 (02-15-2015)
Received 13,090 Likes
And among the most knowledgeable is whiteXKR, so please follow his advice without delay so that we don't have to read about another engine replacement needed because of failed tensioners.
It's critical to replace only the secondaries, although doing all chains, guides and tensioners would be good if you can afford it.
Received 9,010 Likes
I was told by the previous owner that my '98 XJ8 had metal tensioners fitted just after he bought it but was unable to provide receipts to prove it.
Is there a procedure on here somewhere showing you how to take the covers off and check? I have searched but failed to find what I was after.
Glen.
Glen.
There are several procedures written up with photos on tensioner replacement. I am providing a link to a very comprehensive one that has far more information than you need, but you may want to keep it in case of future need.
Obviously (I hope), you will not have to remove the bonnet and radiator, so you will have to skip down to removing the air inlet tube, but not the filter box, and then to the coil cover, coils and valve covers.
Tmingi chain and tensioner replacement
retromotors (02-16-2015)
Thanks for that link.
I've been reading and collecting all the info I could find on X308 timing chain/tensioner replacement, and that is definitely the most in-depth DIY how-to I've run across. Great photos.
The first writeup I've found that actually explains how some of the special tools are used.
Regards,
Retro
Can I chime in with a question?
I'm looking at a 3.2l V8 in a few days and that probably hasn't had the secondary tensioners changed. Rumor has it here, if the tensioners do snap/break/f**k up on the 3.2l, the valves won't make contact with the pistons...
Is that rumor true? I can't really believe it as being a multi valve engine with angled valves, that must contact somewhere along the lines...
Glen.
Glen.
Brilliant, many many thanks.
