xjr rear wheel bearing replacement
![Icon Idea](https://www.jaguarforums.com/forum/images/smilies/icon_idea.gif)
Complete bull. Take it somewhere else.
It is no harder to do this than any other wheel bearing. I did this in my garage with a good set of punches and a normal everyday press to refit the races. And even to sub it out, unless they're replacing it with a 24ct gold bearing, $900 is just plain offensive.
You could buy the tools, new hub nut, press and bearing kit for a fraction of that and still have over $500 left!
A "proper" bearing job at a mechanic should be about $400. For my car in question, I had that done, but the replacement bearing failed multiple times, it turns out the hub carrier was bad. Replacing that solved the problem for good.
-Mike
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Doug Dooren
08-30-2015 08:51 AM
