Hi
A few days ago afther the engine reach the normal temperature a see from the engine compartment coming steam i stop the car and try to find the source of the steam. One conector on one pipe coming ftom the engine to the heater sistem start to blead at high presure, i make a photo of the connector but i do not find it on the program, can any one help me to identify?
Norma is a company that supplies quick connect/release ends for many companies. You can purchase the end by itself and try replacing it if you want to be frugal. Look on eBay for Norma PA6 GF50. But I will assume you want the whole hose to replace?
Without a larger pic of the area you are speaking of I hope this helps you locate the piece you need?
Hi
A friend of mine told me that inside this connector it is an O ring and can be repleace.Opel use this type of connector and he fix a lot of them by repleace only the O ring
Best regards
Hi
I fix the problem today. Change the thermostat and cut the hose rapid connector. It was impossible to change the o ring, i put the hose direct in to the pipe using a hose clip
Best regards
