XJR sunroof
XJR sunroof
I have a lovely XJR only thing is I can't get the sun roof to open and shut properly. When I push the button to open it it opens right back (past the normal open position). The consequence is drumming from the air passing the roof. When I try to close the sunroof the motor takes it past the closed position, raises the rear if the roof then closes down and opens to the far rearward position.
The motor operates OK and the wiring appears to be sound.
Does anyone know about the problem and even better have a solution?
The following 2 users liked this post by motorcarman:
Catenaccio (01-05-2014),
jimlombardi (05-28-2011)
MidwestJag (01-03-2014)
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
