XJR suspension and brake light issues
Thanks in advance everyone, i have been on here looking up information
and can't believe the knowledge and camaraderie. Have had my XJR looked at
and will get the laundry list of problems tomorrow but can't wait. I have been
told the worst is the suspension. New shocks and mounts needed on all four
corners at over $300 each. I read on here that problems with the actual shocks
on the XJR with adaptive suspension (cats) are not very common and it's
usually the mounts or something else. Is this true? Also, i have no reverse or
brake lights. Fuses and bulbs checked and the relay is picking up. Lost and
in love with my Jag and want to show her off properly without issues.
![Icon Redface](https://www.jaguarforums.com/forum/images/smilies/icon_redface.gif)
Depends on your mileage on the shocks. My 03 XJR has CATS and before a mishap, they were shot anyways. So I'm putting on normal bilstein shocks on all 4 myself($400 total) and disconnecting the cats module. While you do it... Change the upper and lower shock bushings and sway bar bushings.
As for the light, check the connection for corrosion.
FirstJag7979 (02-13-2013)
Also which Bilsteins are you using and do you get an error message with the module disconnected? And i will check for corrosion. Thanks
Bilstein Shocks: 98-03 XJ-8 with Sport Suspension - eShocks.com:
FirstJag7979 (02-14-2013)
BrentGardner
28
04-26-2024 03:08 AM
