xjr sway bar bushings stock or upgrade?
I need new sway bushings on my 2001 xjr. I found then at the dealer and they are not that expensive only about $13 each. i just don't know if there are any upgrade bushings that may be better or will these be good. The originals seem to have lasted 130000 miles so i would think they would be ok but does anyone have any better ideas?
thank you
jimmy
thank you
jimmy
I recently replaced mine on my xk8 with the stock bushings from Jag. I do know that Matt H20Boy used the poly bushings on his xk8. This might help https://www.jaguarforums.com/forum/s...ad.php?t=33782 I did mine differently but we are also talking about xk8’s not xj http://www.gusglikas.com/images/Auto...erBushings.pdf Hope this helps!
I put the superflex on and they can be found on another thread in the XK8 forum. After driving with them for several months, i think the stock ones would be just fine.
I've been advised by the technical director of the J.E.C. that the standard anti-role bar bushes rubber a a fair deal harder than Poly, I mentioned to him I was thinking of changing all the front end bushes to poly, and he said use the Jag ones or you'll not get the correct handling. I took that advice, the guy know's these cars, and they're cheap!
The 300 I said for Superflex is for all 6 front end bushes but you need to keep in mind the life span is about 3 times as long as rubber if properly cared for. With the cost of an alignment each time it makes long term economic sense to me.
You'll find it is on the anti role bar bushes. I'm referring to the XJR bushes. You get a stiffer compound of rubber, by a lot. I want my car like it left the factory. To be honest, I'd take his advice over yours all day, the cars where designed developed and built here, and he was part of that process, what's your imput, crispness? I guess you race yours.....
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
jagent
09-07-2015 05:00 PM
