XJR tranny fluid change- how many quarts?
Its been 30k since I had it drained, new filter and filled at the mercedes dealer Thinking I will do it myself this time and just use the drain plug rather than dropping the pan (unless the fluid that comes out looks nasty). If I just drain, how many quarts of the Merc fluid should I have on hand?
TreVoRTasmin (03-31-2016)
If you are doing a full drain, you will need 7.5 LITERS. Unfortunately, the XJR 722.6 tranny does not have a drain plug in the torque converter. My Mercedes C280 722.6 fortunately did have a drain plug in the torque converter and it was 7.5L. If you drain from the pan plug only, you will miss about 1/2 liter, because the top of the plug mount is about 1/2" higher that the bottom of the pan and that fluid below the plug mount will not drain. It is really easy to just undo the six bolts holding the pan, after draining the pan. Use only the Mercedes ATF 134 fluid, even though it costs about $23/liter. Otherwise you may get slipping after a few thousand miles, and by then the damage may already have been done.
Here is a thought, the next time you have to pull out the tranny, consider replacing the torque converter with another one with a drain plug. And don't forget to buy a transmission dipstick. 722.6 trannys run best when at the full mark.
AJ26 XJR has drain plug. Copied from MB forum: "All drain plugs were deleted by 30-09-99. "
TreVoRTasmin (04-01-2016)
good afternoon
I have 2 XJR, one BRG one black, both had the same tranny issue with fault code,slip gear. here is what you need to get and done. issue was fixed on both cars so I have 100% confirmation that could be fixed. DONT waste money for just changing the ATF.
For Mercedes Transmission Conductor Plate Connector Filter Gasket 722 6 | eBay
Shell ATF 134 Mercedes Benz Transmission Fluid 236 14 236 12 6 Quarts 5080660 | eBay
I have had zero tranny issues with my 03, just fluid changes every 30k or so no need to replace parts for the sake of it. And my 03 has a drain plug on it. Just verified yesterday.
good afternoon
The conductor plates are known to fail .... but the much more common problem causing the same issue is the connector. The OE part is available for $12.00
TreVorTasmin - the drain is not the drain pan. They all have the drain pan -- the early version MB transmissions had a drain on the T converter.
The R has the MB box -- the non SC cars the ZF. The MB box will use 1st if in sport.
When the MB electronic transmission came out in the mid 90's. Two things were in mind -- the transmission required what was then a new and not widely available fluid and the normal life of a car at that time was under 150k.
Knowing that many owners would use the wrong fluid and the vast majority of the cars would die with functioning transmission -- they called them Lifetime.
I have had many cars with the MB box and the only one I touched was the one needing a new connector.
As for the tranny, I like to tow my camper at speeds near the "ton" so I've always looked at tranny fluid as a much cheaper alternative to a transmission rebuild.
The transmission were designed in the very early 90's for later 90's introduction. Cars did not last as long -- both mechanically and body (rust) Paint.
Even MB .. who had the largest segment of long term owners had very very original owners past 150k and 7 years ... that's lifetime in the auto business 1998.
How old are you? How old was your first car.
Old enough but young enough to not have owned any cars from the 70s. I do one thing that 98% of the population doesn't. I take care of my cars and believe strongly in preventive maint and care.
I don't even have a single electrical issue with my TVR (at the moment
that is). Only tranny issues I've ever had were on the Subie SVX and XK8. Bought both knowing the tranny was the weak point and bought priced as such. Both needed a rebuild before they hit 100k.
no one is lecturing no one else here and at the end of the day we all make the final decision of the car we own.
I did what I did was because it has fixed my issues of both XJRs and proven permanent resolution for a total cost around 450 bucks(parts and labor) and 722.6 tranny has tendency to fail and the plate and connector will get wet and slip. if not now, one day(actually soon considering the age of X308)
I can not think of any reasons why not doing it (at least for me)
The OE MB transmission filter -- Has a small fleece at the pick up and and had what I would call a screen inside. (last I dissected). I was sad to see that the latest Mann aftermarket, while still metal was made in China. The electrical connector can be a huge problem -- On the MB's the fluid can actually travel up the harness and flood the control inside the engine compartment. It was a quantum leap in transmission technology -- especially considering how bad MB transmissions (auto) were in the beginning.
The first set of fleet cars that all made it to 200k were our 2000 Lexus ES 300's -- some of my employees are still driving them with 300k +.
I think just like the exact purpose for the existence of this forum. We are sharing out the experience and knowledge of the same car we all love.
