XJR Transmission fluid
#41
#42
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Given that this thread may become the canonical thread for the solenoid upgrade on Jaguars running the W5A580 transmission, the major parts of the procedure are:
1. install solenoids
2. reset tcm, probably by full powertrain reset as described elsewhere since most people will not have a spare tcm
3. enjoy
#43
#44
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Make sure you pay particular attention to step 3 above: "enjoy"!
#45
I replaced the solenoids on my car a few weeks ago, what a difference. The other thing you want to change is the connector for the plug in the transmission. I purchased the pan gasket & plug from the local Mercedes dealer for $45.00. The solenoids are not cheap but make a huge difference in the shift quality. Here is a link on the installation.
Feedback/How to: Install SHR Shift Improvement Solenoids - Lx Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum
I was shocked at how much cheaper the parts were from Mercedes, they are half the price I would pay as a dealer employee.
#46
#47
One other thing while under the car ... seal the dipstick tube at the transmission with RTV. There is a Chrysler TSB out on this because water seepage at this joint can cause slippage at concentrations as low as .05 percent. The TSB calls for the RTV and a TRIPLE flush of the ATF once water gets in.
#48
Just bought a super cheap low miles 722.6 out of a 98' UK XJR......it's cheap because the fool that dropped it didn't take the torque converter with it......
Can anyone tell me anything about the early MB boxes compared to the later, say 01/02?
The one thing I've come across is the drain plug on the early torque converters, is there anything else, like bearing updates etc on the later boxes? I'm about to install blue top solenoids in it, then fit it to my rebuilt motor.
plums (10-19-2011)
#50
#52
Sean B (04-12-2012)
#53
Not sure if this thread made it to cannon or not, but seems legit as anything I came across so apologies for the necro.
I'm looking for the latest info for my 1999 XJR. Ready to do a fluid exchange, and thought I was good to go, but the seller cancelled my order of this: http://www.ebay.com/itm/351319490140
And said I needed to order this instead: http://www.ebay.com/itm/361226082235
Any suggestions on this would be appreciated.
I already purchased the connector plug, but I would also greatly appreciate help sourcing the blue solenoids.
Thank you much!
Thank you much!
#54
#55
#56
#57
For what it's worth, I put Valvoline Maxlife Dex/Merc in my 98 XJR transmission about 45,000 Km ago. No issues to report. I also called Valvoline prior to using it and they assured me it was a good choice. I bought it at Walmart.
I mention this because it seems some members are struggling to find transmission fluid for the Mercedes units in XJRs.
Other members may shudder to think of using oil purchased at Walmart, but I have been quite pleased with how it performs. 45,000 K may not be a torture test, but no signs of concern have been detected.
#58
#59
this one will work too
Shell ATF 134 Mercedes Benz Transmission Fluid 236 14 236 12 1 Quart 5080660 | eBay
