XJR transmission issues
The transmission on my 2000 XJR is acting very oddly these days. Shifting is very poor when first driving the car in the morning. Shifting from Park to Reverse there is a delayed reaction before the car goes into gear. Also there are several warning lights on the dash that are lit up such as the anti-lock brakes andtraction control. Not sure if the warning lights are related to the transmission or if that is some other problem. Car appears to drive fine once it warms up but the warning lights stay on untill the car is shut off. Starting the car again will often clear the warning lights.
2000 XJR, 70K miles
2000 XJR, 70K miles
The abs light is not related to the transmission. You would need to get codes read to be sure what the fault is. We could all guess on here, and be way off. Need the codes to tell you for sure.
With the transmission, there is a bulletin for supercharged cars, to replace the transmission control module. I think. It may be for the XKR. I will research it and repost.
EDIT - The TSB is for normally aspirated XJ/XK Vin A00083-A30644 and F00103-F59525
Sorry for the confusion.
Guest
Posts: n/a
I'm new here but been playing with my 2003 X-type and 2002 XKR conv for about 4 years. The abs, traction control are linked to the transmission. First check your fluid level. Also check the Illumination module and make sure they light up on the selected gear.
Let us know what happened
Guest
Posts: n/a
Maestro...
I have a 2001 XJR... could you tell me the length of the dipstick so I can make one?
I have 60,000 miles on mine and I took a sample... ugh! Brown with a tad of pink
in it... Trying to find Shell ATF 3403-M115 is another story!!!
Your help is appreciated...
Jeremy
Jeremy
2001, 2002, codes, fault, forum, identify, jaguar, light, mb, module, problems, transmissins, transmission, transmisson, xjr
